Myself
manic mechanic
- Twin Lakes AR
A customer of mine has spent too much money already on this project. Basically he was lied to and I had to repair the driveline and rebuild the carbs before it would run. Then we had an electrical issue. Then got hard to start and he found low compression. He had the cylinders bored, has new .25 over WSM pistons, then he tried putting it together and broke a ring. He brought it back with new gaskets AND crank seals and wanted me to go through it. Upon disassembly I found a damaged rotary valve cover (previous) and witness marks on the stator.......crank snout has .013" runout and a loose rear main bearing. Basically he is DONE spending and wants to be rid of this nightmare. It needs a new crank and reassembled. Lots of work already done. Engine parts already cleaned and surfaces stoned as well. He also has the extra big float thingy on the back. He has papers and it sits on a decent trailer. ANY OFFERS WILL BE CONSIDERED. Machine is in average 1995 condition but NOT a beat up pile of crap.
