i refoamed my ski and with my luck i ran out with about 5 ounces of area to go :banghead: :banghead: so i was seeing is there anything i can substitute in there for the foam?
Just fill it up little by little because it needs air to harden, if you don't do it little by little it will be a hollow area under the foam.. (found that one out after wasting a can trying to make a mold)
Home depot, menards, lowes, etc... all should have it (I'm sure you know that but just incase)
