I just installed a Jet Works flow control valve on an SXR with Factory wetpipe. I had a nasty bog doing tailstands . This clear up the bogging, completely.
I had a bit of a problem installing it but got around it.
First i tried just splicing it into the hose that runs from the bottom of the T-fitting to stinger. This didn't work that great. Even a high throttle, very little water came out unless I lowered the pop off pressure to almost nothining.
I flipped the T-fitting around so the water out line has a straight shot to the FCV and the 90* part of the 'T' goes to the pisser. This pumped all the water the stinger would ever need with the rest escaping out the pisser.
