Fiberglass
I need to glue in a new pump shoe into a Kawasaki couch for my wife. The couch is fiberglass an the new pump shoe ,or intake guide as the dealer called it is plastic . I was hoping someone had a suggestion as to what I should glue it in with. Thank you
hydrostyler
X-
Central Illinois
A lot of guys will use 3m 5200 ^^^ which takes days to cure, or an adhesive called plexus. Its a bit pricey and requires a special gun. The ingredients is nearly identical to permatex or devcon plastic welder. I've used the permatex plastic welder for a few pump shoes and haven't had any issues. You can pick it up at home depot or lowes for about $3 a kit. fyi, epoxy doesn't like to stick to plastic
