Fathom's Square
Fathom
WaveJunkie PR
Central Illinois
Engine:
701, 61x cases, 61x cylinder
Group K milled head (175 psi)
44mm carb, Ocean Pro flame arrestor (stocker in standby)
Factory B pipe, Limited chamber, Parr's screws with T's
TDR waterbox
Monkey Grips mounts
Electrics:
No rev limit CDI
Stock 61X flywheel
Odyssey battery
Pump:
Stock 144mm pump
Worx 201 grate
Skat Super Slim Line 14/18 set back
Stock plate
Steering:
AC pole -2
ODI Ruffian MX grips (black rings)
UMI steering with JSS rebuild and SS bearing
UMI zero degree bars (black)
UMI billet throttle lever (black)
UMI limiting rope
UMI pole spring
Hull:
'91 stock white de-stickered
Billet 45 degree pissers (silver)
Atwood 500 gph pump with JSS short switch
Stainless steel battery box
Hydro Turf mats in tray and rails (diamond black), 25mm underpad in tray, 8mm under elbows
CG holds
DIY one-way valve
va
Wow thats dirty, ever heard of soap? Clean that thing!!!
:biggrin:
Ooops,I was looking at my ski :nutkick: not yours. Very Pretty :biggrin:!!!!!!
