Fathom
WaveJunkie PR
- Central Illinois
Engine:
701 Freestyle ported by Keith Head (Head Enterprises)
R&D one piece pump gas head with dual cooling
Epoxy filled 61x cases
Freestyle ported 61x cylinder
Wiseco pistons
Carbon Tech reeds
48mm Blackjack carb, Tau Ceti flame arrestor (stocker in standby)
Port matched 61x intake
Factory B pipe, Limited chamber, Parr's screws with T's
Riva waterbox
Monkey Grips mounts
Electrics:
Riva CDI
Lightened 61X flywheel
Odyssey dry cell battery
Pump/Steering:
Stock 144mm pump tapped for dual cooling
Jet Dynamics grate
Solas Yamaha YB-CD 13/16 set back impeller blueprinted and balanced w/ rec finish
Stock plate
ODI Rouge grips (silver rings)
MSR bars (black)
Dakine straps
UMI billet throttle lever (silver)
Hull:
Fully reinforced hull (bondline filled, sides and transom, body filled in at oil level viewing area
Painted Imron single stage yellow
UMI tank cap (black)
Billet 45 degree pissers (silver)
Atwood 500 gph pump with JSS short switch
Single duckbill
Hydro Turf mats (black)
Hydro Turf seat with shaved hump (yellow/black/silver)
Polished Jimmy Visser style seat retainers
Wiseco pistons
Carbon Tech reeds
Riva waterbox
Monkey Grips mounts
Electrics:
Riva CDI
Pump/Steering:
Jet Dynamics grate
Stock plate
MSR bars (black)
Dakine straps
Hull:
Single duckbill
