Factory Wetpipe on an x2
Now i know it has been talked about 100times, But i thought i should ask this question once more and please only answer if you are sure of the answer you are giving.....
Ok my mate has a kawasaki 750 wetpipe (some people call it a B-pipe) that i would like to fit in my x2... Now i have the manifold available to me also. and i want to know if it will fit??? Currently i am running a westcoast pipe with a westcoast manifold, which isnt great on my 780cc
I know most people run the blaster limited/mod/superjet pipes but is that becuase they are just a better fit?? Whats limmiting the 750 wetpipe from fitting?? J
jae
Well i tyed it out.. and the simple answer is it wont fit, with the factory 750 wet pipe engine manifold bolted to the header manifold the header hits the hull on the x-2.. tryed using the westcoast manifold and then there is no way the expansion chamber will bolt up to the header pipe.. also with the 750 expansion chamber the standard x-2 tank wont work either (not even if you melted it), so a kawi 550 or home made one would have to replace the standard type. I guess the only option wond be a hull mod, or to extend the exhaust chamber once the factory header is bolted to a westie manifold..
the simple answer is I borrowed a superjet limited, which will bolt up to the factory header from the kawai wet pipe, with the westie manifold. ill try that and see what the improvment is from the westcoast one i had on it last week.
