- Jourdanton, Texas, United States
I was just wondering if someone could explain to me exactly what the adjustment screew is adjusting on a factory pipe?
if your headpipe is not attached you should hook it up to a hose and check it out, I have noticed that adjuster screws do not all spray identical with same turns open, and even had one of the holes ( tiny hole ) clogged !!
Common problem with these headpipes. I run a wire through mine at least once a year or if I feel a performance difference.and even had one of the holes ( tiny hole ) clogged !!
