Blaster Factory Bpipe HELP!!!
I'm in the middle of installing a Factory Bpipe Mod chamber in a Blaster and ran into a few issues.
First of all Clearance where the head pipe and chamber connect is not adequate because of the foam, what is everyone doing? Removing that entire block or just trimming off what gets in the way? It looks as if it would need quite a bit of trimming because of the exhaust hose that runs back to the tunnel also must run underneath the head pipe/chamber.
I also do not have the "L" bracket that came with the exhaust originally, could anyone give me dimensions of the "L" bracket or post any pictures so that I can have one made?
Thank You
Mike W
Infidel
North Florida
That template is for the bracket that attaches to the stator cover, I have that bracket. I'm looking for the "L" bracket that mounts to cylinder jug just above the manifold.
Gotcha... That is just a simple bracket you can make out of a thick piece of stainless. I made one a several years ago because FP no longer makes them.
