Factory B pipe - no cooling needed?
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
I was talking to an experienced guy and he told me that it is possible to run the Bpipe without cooling. Only the manifold must be cooled (since freestyle is not about WOT). I was thinking to try this to gain more power from by Bpipe.. any opinions?
Maybe the builders can chime in? :)
Thank you
Mouthfulloflake
ISJWTA member #2
NW Arkansas
You must have a little bit of water to keep from melting the hose between the chamber and water box.
Once you have that much water, thats all you need.
that is how I FINALLY figured out how to set mine up.
It will melt hoses with no water, I know that for a fact.
Polish jet pilot
Warsaw, Poland
Cool, how do you run your screws then> Bottom open 1/2 turn? Or you dont use the screws at allOddly you mention that the rubber from chamber to w/b will melt. I always thought that the first thing to melt would be the coupler?
How is your cooling set up (for exhaust)??
Thanks!!
