- seattle area, Wa
Riding seasons here, are you still fighting the Keihin carbs on your Kawi 750 or need to get your SXR carbs on your 750? Jealous of those Yamaha Mikuni carbs that seem to be much more reliable than the Keihins you have? Check out these adapters that may help with dialing in your 750/800.
Kawi 750 -> Yamaha OEM dual SBN 38
•Ditch the dual Keihins and get a set of yamaha dual Mikunis on your 750 without the cost of aftermarket SBN’s. $75/ea
Kawi 750 -> Yamaha OEM dual SBN 44
•Great for ditching the Keihins when you need a little more carb than 38’s, like when running a pipe, porting, ect. $50/ea
Kawi 800 -> Yamaha OEM dual SBN 38
•Got an 800 that’s missing the oem sbn i40 carbs? Yamaha 701 38’s are a reliable replacement without the absurd cost of oem sxr sbn i40 carbs. $75/ea
Kawi 800 -> Yamaha OEM dual SBN 44
•Need larger carbs on your 800 but without the cost of a new intake manifold and aftermarket mikunis? Bolt on the popular Yamaha 760 sbn 44’s with this adapter. $75/ea
Kawi 750 -> Kawi OEM SBN i40
•Got a set of 800 carbs but missing the rare and expensive 800 manifold? Bolt the 800 sbn i40 carbs to a 750 Keihin carb manifold with this 3-piece adapter set. $90/ea
All adapters are 6061 billet T6 grade aluminum, anodized for corrosion protection, and come with all necessary hardware for mounting and carb installation.
Check out Evolv Manufacturing on FB and IG for more details, other part offerings, and new releases as they come.
