- Texas
My freinds have been riding my jetski (better than i have AKA no subs) and last week it stopped starting(but turned over till battery died). So today i had it with a fresh battery and i removed the spark plugs, saw they were filthy(due to a dirty water) and used a lighter to clear out the chamber but the water wouldnt burn. So I know it's some mix of fuel water (partially because of starting fluid sprayed in the intake).
I turned the engine over for 30 seconds w/ spark plugs removed and water is "misting" out of the piston chambers. Is there something else i should do to clean out the water? I think this filth water is keeping it from running because it immediately fouls the plugs.
Also worth noting, it was turning over really badly when i started but after a while and with plugs off it got better and better. I have been riding in salt water about 5 times this summer/spring.
Any advice? If possible i'd like to try to fix it tonight..
