Other Engine parts cleaning?
Delaware
SpecIfically a crank. Got a good crank I want to use that got dirt, rust, etc on it from tearing the motor down.
I don't have a parts cleaner so I have rinse it another way. Can I just use water and oil down afterwards or something else besides water better like break clean, gum cutter, carb spray?
:confused:
Thanks,
58vwragtop
Braap Certified
Blue Springs, MO
WD-40 works as a good cleaner and on rust. I also use mineral spirits (paint thinner) to do a lot of cleaning on greasy parts. Also compressed air from a compressor if you have one to blow all the liquid cleaner out of the bearings. Just oil everything down afterwards.
Waternut
Customizing addict
Macon, GA
Why not just use premix? Gasoline is an excellent cleaner/degreaser and the added oil will help keep it lubricated.
Way better than water and a lot cheaper and safer than carb cleaner.
