Eme and pfp
uk
Hi all, so I've got a eme q8 with xscream xs1000 in it and a pfp in there too. Needless to say it's a bit tight. The problem I am having is I can't seem to get any breather pipes from pole tubes down into hull as the pfp chamber is right below where I need to be. Have any of you guys found a way round it or a flexible pipe that bends enough to fit in! Any pics would be great. Thanks
Mine was super tight in my Q8 as well. I had the plastic abs bushings around the breather tubes and only had to trim a section of one of them to clear the chamber. I cut/welded my pfp waterbox to fit better and angled the inlet tube down at a 45 to get the chamber to lay down as low as possible in the nose.
uk
Thanks, my waterbox fits great, I think I might drill the breather holes further back and angle the tubes towards the engine, like Eric malone said to me he has had to route the steering cable Infront of the chamber! Will post some pics of the outcome!
N3vrSat1sfied
Military Member
Fort Worth, TX
Mine actually has some pretty good room in the Aerial 8. I just have to bring the breather tubes slighty towards rear of ski (engine side of chamber) Then they should clear pretty good.
