Super Jet Ebox Question
I am putting the ebox in the SJ i am building, its a 97 RN
Does it matter which of the red cables i hook up to starter and which to battery, both connect to starter relay correct?
Also i am using a CF ebox mount is it ok if the cables come out of the bottom of the box? (upside down) or is that the correct way?
VXSXH20
Sionis Industries
Mid-Atlantic
yes it matters which red wire goes where! ... one is going to be hot at all times from the battery lead. The other is bridged to the starter via the starter relay and will only have power when the switch snaps the circuit in the relay and connects the to leads thus powering the starter.. as for and upside down mounted box.. no that does not matter as much provided your cables are still connected to their correct locations..use di-electric grease on all the connections and terminals you can.. Good luck
It does not matter what terminal on the relay the cables connect to. What matters is: the cable which goes to the battery has a small wire coming off it ( if you're using an oem cable), which connects to the fuse. let me know if this is not clear and I'll try posting a wiring diagram.
