FX-1 ebay find kawi 650 stock pipe adapted for 701....really?
hhh
There good but not at that price. Plus the Kawi pipe should be modded for a real gain. If you can do it for 200 or less it's better once you get into a pipe for 350 there's better options
VXSXH20
Sionis Industries
Mid-Atlantic
what has to be modded on a kawi 650 pipe for the fx1 on a 701? i have a few i stare at all the time. hate to throw stuff away especially if it can be reused on another ski..?
WFO Speedracer
Alabama
http://item.mobileweb.ebay.com/viewitem?itemId=280936834390&index=4&nav=SEARCH&nid=86607789166
Is this as crazy as I think it is ir is it actually possible to make better power with this setup then the stock 61x pipe?
I'm mainly asking because I have a 650 pipe right here and I don't have the cake to spring for a b pipe at the moment...thanks guys.
It makes much better power that the stock Yamaha pipe,l all it takes to mod the pipe is some JB weld a few drill bits and some brass fittings.
A pipe made from cardboard would do better than the abomination Yamaha put on that motor.
I almost did this mod. But then I found a sj mod pipe. Super easy to install once you find a manifold. Find a factory pipe mani and drill a hole for a stinger. And your done. Looks better then stock too. Lol.
dfw
Its the coffmans 650 Yamaha manifold that is hard to find.
based on factory's site.
Main Jet : 145
Pilot Jet : 120
High speed screw : 1 1/2 turns out from closed
Low speed screw : 2 1/2 turns out from closed
Needle & Seat : Stock
Spring : 95 gram
