Super Jet Dual Cooling: Where to Drill Holes in from Pump to Bulkhead? Pictures Welcome
I have decided to keep the stock bilge, so I need to run a new line from the pump through the bulkhead. I will be using a piece of 3/8 stainless.
I assume your drill From the pump TO the bulkhead?
Please post any tips or images showing where to drill.
Thanks!
How bout a pic or two?
I found some slow dry 5200 at home depot. Thanks tx...96.
After I finished test fitting the tubing, I put a bunch of 5200 inside the holes before final placement. I might of went a little overboard in the engine compartment. Oh well...
This stuff take forever to dry, so I stood the skill on its tail so it wouldn't run as much.
Today I plan on applying more in the pump area similar to the stock bilge.
Lastly, here's where I bought the stainless tubing: http://www.mcmaster.com/#catalog/118/145/=kui15n
Part Number: 8989K482 (Welded Type 304 Stainless Steel Tubing, 3/8" OD, .319" ID, .028" Wall, 3' Length)
As far as the drilling part. Did you just drill a hole in the pump area, then one in the engine compartment and then push the stainless steel tube through the foam and hope to hit the hole on the other side?
and the hole on the pump area is reasonably close to the hull. How did you get a cordless drill with a standard length drill bit in those tight quarters?
From looking at several build threads and based upon the measurements I took from the bottom of the hull to the tubing, I could see that the standard bilge tubing is angled up hill slightly.
So I drilled my holes where I thought they should be accounting for the angle (sorry, I don't remember the measurements).
At the rear of the hull, I placed a couple of black marks and a 3/8 drill bit to ensure I was always drilling at the angle I wanted.
In the end, I was off maybe a 1/2'' vertically (low), but nothing a slight bend in the tubing couldn't fix.
As far as the drill and bit, I used a standard size craftsman drill with one of these bits after I got the pilot hole started: http://www.harborfreight.com/3-piec...dium=email&utm_campaign=0113a&utm_source=1009
I pulled the last picture from someone's build thread (don't have link as I saved the picture to my desktop). Which shows the slight angle.
Would it work if you drilled the hole in the pump are and drilled the hole from the engine bay, then "fished" from the back hole to the front hole with your long drill bit?
