dual cooling question
Pa
so on a 701 61x/61x im putting a riva red pipe on so, im drilling the pump for my secound line and keeping the stock bilge and running both lines into either side of the exhaust manifold. my question is, with a totally stock motor what lines are what on the head? the larger, looks like 3/8, black hose that connects the head to the exhaust manifold(next to the flush line), is that a return of water being expelled into the exhaust to water box and out from the case and head? so that is the line i would want to connect to my first 6mm pisser thusly bypassing the dump of water into the exhaust?
the secound, much smaller line in the head that goes right into the end of the stock pipe what is that? is that the line that would go into the bottom stinger of the pipe which then goes to my T which goes to the secound pisser and the end stinger of the pipe, with flow restrictor between the tee and stinger?
I love pictures so please feel free to draw or pm what ever.
ND
i just hooked up dual cooling on my superjet actually last week. Go to wamiltons website and find his modded pipe. there is instructions on there and a picture which I am thinking might help you out.
