- St. Louis
Okey doke. After much searching, reading, etc. I'm more or less sure of the general idea of what i'll be doing for my dual cooling.
Just wanted to throw up a diagram for anyone to critique.
Question though: I am using my stock exhaust manifold, which is only set up with one fitting, so is there room for a drill/tap second fitting, or should I just stick with one?
The photo is my drawing.
Other than that, does my setup look good?
and before anyone says "make sure you need it", I'm doing it for not only piece of mind, but i plan on getting a LPW port this winter, :love:, so i figured I should do this now while im in the pump area (pump cone), and installing a "new" pipe.
Thanks for any help guys,
Geoff
Geoff
