Yamaha OEM 44mm carbs setup as duals. 118mm centerline (Yamaha) or 120mm (Kawasaki)
3 hole transition carbs with 12 degree plates (NOT GP760’s) One plate & shaft brand new OEM Mikuni to convert from single to dual.
New gaskets in the pumps – completely rebuild this Christmas. New OEM mikuni 2.0 needle/seat and 80 gram springs
Jets setup to try reverse jetting 130/115 Top screw has crossbar. Bottom screw has epoxy knob. (OEM Yamaha bottom screws are Stainless)
One carb has dual primer fittings so either side can be accessed – other carb AB epoxied holes (only need one carb’d primed if using primer)
Aluminum coupler. Never ran since put together.
Condition: Excellent
$125 shipped in USA
$125 shipped in USA
