So I just replaced my driveshaft bearings and I noticed the shaft has a lot of vertical play at the pump end. There is about 2 and a half inches of movement, but thats because the shaft tubing is stoping it from going any further. Wondering if someone could provide some insight as to wether this is typical or not?
Im assuming the shaft is seated completely but I could be wrong. 50mm exact between shaft coupler and bearing housing.
Any help is appreciated!!!
