Flywheel cover has a brass insert and 2 springs that install in it and they are pretty beefy... i found this thinner spring in the bottom of of the hull and i'm not sure if it's part of stator area / idle gear assembly.
Any advice?
Also how tight should the 2 stator bolts be? The manual doesn't list those specs. i tightened them to 5.6 ft-lb. is it ok?
Manual doesn't list the specs of 7 flywheel cover bolts either... how tight should those be?
Any advice?
