does this cheap pipe look worth running on RN ?
this pro tec pipe for a blaster had it's "outlet cut, turned and welded to fit a RN SJ" per the current owner who wants to sell for real cheap....would you run it ? does it look like it will fit now with the weld job ?
#ZERO
Beach Bum
Florida - U.S.A.
Ditto.... extremely heavy pipe because it's all cast aluminum.
It corrodes very easily in a saltwater environment and it does produce good all around power.
AtomicPunk
Lifetime bans are AWESOME
Largo, Fl
agreed it is heavy... no corrosion on mine at all and I ride saltwater regularly... it has never come apart either.
I think it makes good power... never had a b-pipe with my setup to compare against.
Boris
The Good Old Days
how about if it was like $75.00 cheap ?
Then stop asking questions and RUN !
Get that thing ASAP or give me the info.
Seriously, at that price you can't go wrong. If you don't like it you can always clean it up and sell it. Put the proceeds towards a b-pipe and have a nice day.
oldskoo
local jackass
Cleveland Ohio
i ran that same pipe on my b1.....i had the head pipe
welded to the manifold, made it harder to take in and out but i kept ratting loose/shearing those bolts off, and it use to eat those damn lord mount bushings, i eventually made my own of urathane........made decent power for 75$ what the hell
Q
QuickMick
Guest
If the price is right than grab it.
Better than the stock pipe and you can always resell after the b-pipe arrives.
This is the truth. Use it till you find a B pipe. Then resell.
FreestyleFreak
Region 7 AM Freestyle
I ran that pipe on my old 6m6 SN.Never had coupler problems or anything held together good and even road the surf a few time,it makes decent power.I payed 200 for mine!
