sfab
X
- Canada, QC
hi folks,
ive did a couples of search on the subject but im still a bit confused. what i want is to put 760 stock sleeve into a 61x cylinder (have access to a machine shop, been a machinist help :biggthumpup: ). i thought all ill have to do is to bore the cylinder casting to the size of the 760 sleeve minus fit tolerance and bored it to 85 and here it is, a 771cc beast! (with some minor carbs ajustemnt, of course). i do know it can have some ports timming issue and was wondering if i only want bottom end will it be critical or i can just leave the ports stock. thank you in advance!
