Super Jet Did someone set this up for dual cooling?
550headache
tobacco grower
tobacco valley
Getting ready to install my pump and mid shaft and found this
Is the line on the left for a second cooling line? This is the inside firewall.
What line is the main water feed?
Sent from my iPhone using Tapatalk on the farm.....
550headache
tobacco grower
tobacco valley
Great. What line in the pump area is for the bilge? I'm guessing one on the right?
The bilge nipple on the pump is like half inch in diameter. The lines on the hull are 3/8. What do I do about that?
BruceSki
Formerly Motoman25
Long Island
Try to heat the hose to make it slip over the larger fitting.
You can hook the lines up however you want. Just make sure you know which one is which from the pump to the engine bay and dont swap them.
A bilge line on your headpipe would not be good. Same as a waterline going to your bilge. You'll flood the hull.
Once you put the pump to the hull and mock it up, you'll see where the lines need to go. It's pretty straight forward.
