Mark44
Katie's Boss
- 100% one place
Any one know of a place to get one cheap?
Mark44
Mark44
how much is it at Grainger?
are these the same as the GM weatherpak connectors weve all talked about before?
if so you can do it without, if you are VERY careful ( ive done it- and im rarely careful!)
Do you need one to properly install the Deutsch connectors?
I just ordered a few 4 pin sets (for my start/stop switches), and from my TL experience it doesn't appear it would be all that difficult to do.
Thanks for the tip....I def. want to do it right. That's why I am going with these connectors in the first place.
doing them right meant soldering them to me, and the little rubber flanged O rings still seal off the connector.
wire is copper, conductors are coated aluminum, they corrode eventually in my experience.
But to each his/her own.
I can order from grainger at a slight company discount if that helps you any.
I also solder them after crimp for for that extra security.
I do the same on my plug wires.
yep, I did some plug wires this weekend just like that.
:biggthumpup:
I use the vice mounted crimping tool for the plug wires I am to cheep to buy the hand tool plus I don't use it but once every couple years.
You guys are funny.
I need to do plug wires, too. I bench-cranked my TL motor this weekend at Phill's garage - we had a few nasty drinks - and waddaya know, one plug wire got caught by the coupler. Clean cut.
:crying:
Are you calling me out?
Why didn't I look here. McMaster has everthing including the connectors.
The crimper is 34.18
Plugs are also a good price.
