- Australia Melbourne
Hey guys, Hears the situation.
Dropped a piston in my last Kawi 800..
Rebuilt my motor 6-8 tanks of trouble free riding..
Yesterday my new bendix buggured up so i removed the front case, and flywheel. After doing so i noticed that my front seal was swinging in the air.
Split my motor, Found my Brand new Hotrod Crank's bearing to be missing a small bit of metal, and to have walked pushing the seal out.
Removed bores and found my pistons to look like this,
Rear seams to look really good ( left ) front no to good
Close up of front piston
Engine specs,
1mm oversize
New plugs nearly every ride. 8's
190-200 PSI
Standed head, Slightly milled with Squish adjusted
98 octain fuel,
twin 48's running ritch.
Advent T3 timing
Standed base gaskit, i was told that my motor was slightly nocking, Not burning fuel at low rev's so a thicker base gaskit was needed, No idea if this is true... Rear looks Good, front looks as above.
Any idea's guys???
Hotrod cranks seam to have
tiwan junk bearings..
Currently in the process of trying talk with there sales rep, this shouldn't happen..
Engine specs,
1mm oversize
190-200 PSI
98 octain fuel,
Advent T3 timing
Any idea's guys???
