DASA 1200 SOLD
only two hours on freshly rebuilt DASA 1200 not ninja ported. new pistons (stock bore) , rings , rebuilt crank , every seal and gasket replaced. comes with intake , reeds, and thrust 50 carbs
its set up for pump gas 46 domes (the motor is pulled but i will try to get a compression test if requested )
compression is 210psi per cylinder
selling for my neighbour who's not on this site. he lost his job so he parted the ski out. ill check if anything else is available n post on this tread
SOLD
