- amarillo ,tx
my bottom end i can make adjustments and itll do good then all of a sudden itll keep bogging down. Still think it could possibly b the water adjustments on my b pipe. i may be wrong but when its running out of the water and u give it gas it dont do it. im currently running stock 701 ada girdled head 180 psi compression in each cylinder, carbontech reeds, msd enhancer, b pipe. i havent adjusted my carbs with a tack, i have my hs screws on carb 1 1/2 turns out and low speed 1 1/4 turns out, i also have a jetworks fcv pro, i have it adjusted almost closed,
