SX/SXi/SXi Pro dales cdi igniter
anyone run that 650 bad attitude in their skies. and what is that 650 flywheel in a 750 set up he does. anyone with experience on this? Making my 94 750sx faster.
things I am getting
-factor b pipe
-have a 9-17 scat tracks so I may not need to change. hearing back from my local shop
-dual intakes and carb like on the 95+ sxi
I want to get the flat top high compression pistions with a shaved head? thoughts
dfw
I would not go that rout. Dales ignition is not very pump gas friendly and has no rev limit, something your small pin crank really needs. Keep the stock carb and ignition for now, most power gains will come from the pipe. Adding more than one mod at a time will cause more problems than you would otherwise experience.
