cylinder heat
Pablo
sqeez bth levrs & lean bk
georgia
Does the exterior cylinder temp (manifold side) get high enough to melt the H2O plumbing going to pipe? My plumbing leaving the head lays against the cylinder going to bottom of pipe. Deciding if I need to rerout it b4 first ride.
Waternut
Customizing addict
Macon, GA
It shouldn't but I'd check it occasionally on your first few rides...You can just add it to all the other stuff I'm sure you're going to be checking/tuning your first few rides. I look forward to seeing this blue and white demon on the lake.
