Super Jet Cylinder Boring tips for a rookie
munki63
Epoxy is my duct tape
Canada
I've only really got one question when choosing a size to bore to is there anything to consider that is usually over looked? What size can a 701 be bored to with out having to modify my ADA domes?
Thanks!
Waternut
Customizing addict
Macon, GA
Based on the fact that most places sell domes for 701's and domes for bores 84mm and up. I would think if you go to 84mm you need to get different domes. More importantly though, if you go to 84mm you're basically on your last bore for stock sleeves so if you waste your engine, you're buying another cylinder in addition to anything else you may have lost. Some have had success with larger bores on stock cylinders but it's rare.
ADA 701 domes are good up to 83.5mm, but you need to check squish with the larger bores.
munki63
Canada
I've had alot of free time at work today, in pricing it out sounds like I might just be better off buying xmetal 771 as long as shipping costs don't murder me
