Cut stator wires, what can I do?
yamanube
This Is The Way
Staff member
Mandalor
The motor I bought has the stator wires cut in the middle, anybody on here have the tools and supplies to hook me up with a nice waterproof connection that will be reliable or is JSS my only choice (would like to save some money if possible).
chriselmore_1
high on resin
san jose ca
I bought a 5 pin weatherpack connecter off ebay for 6 bucks. You can crimp em with normal wire crimpers if your carefull. But i would solder the pins and be carefull crimping the rubber sealing boots. Ive sank my boat in salt a few times and had no probs
OCD Solutions
Rentz, GA
Are you looking to have the wires replaced so they are continuous or do you want quick connects installed where the cut is?
Either way I can help you out if you want to send it to me. I bought bulk of everything for doing my Tidy Bilge Harnesses and have the proper tools and lots of supplies I need to use up.
yamanube
This Is The Way
Staff member
Mandalor
I used to work for a large wire harness building company and they tried to teach me a couple times but I am just a stupid CAD guy. I can run a welder but not a soldering iron, wish I still worked there I could get this all done for free.
OCD Solutions
Rentz, GA
There's a couple tricks to know and soldering goes from a nightmare to simple stupid. I have tried to teach countless apprentices how to solder and some get it but most don't.
I worked 6 of my 19 yrs as an Industrial electrician in a gold/copper mine and used to do inline splices on the 4160V trailing cables, jetski harnesses are a breeze.
