Custom superjet
Fully built 701 squarenose superjet. 61x top end 62t bottom.
Parts:
Full factory B pipe
TDR waterbox
Blowsion HC head (still pump gas)
Oem dual 38 carbs
Cylinder done by HSI
Adjustable x scream pole
Blowsion bars and throttle
144 mag pump
Shortened protec ride plate
Im sure im missing things
Extensive work done to the hull including a shortened and widened tray (~4” shorter), rockered/shortened nose. Pole moved forward ~4”. Hood shortened to match.
Could use new turf to be perfect theres a couple tears in it.
Only a couple rides on it since engine was done. Dont make the time to ride it anymore.
Asking $5500. Located on central coast California
