douglee25
m3booooy
- South Jersey
I am trying to help a buddy troubleshoot a 750sx over the phone. I personally have not looked at it yet, but I am exhausted for ideas at the moment.
Background - Bought ski 2 weeks ago, ran fine in water, 30 seconds into running he saw no water coming out pisser, shut it off and found incoming water line hose came off, reconnected line, now the ski won't crank.
Engine - 750sx small pin motor, RAD lightened flywheel (blue in color?), some sort of taper bore carb, stock everything else.
Problem - We have narrowed it down to an engine that does not want to crank over. The motor is out of the ski and ebox is not connected. Hooking jumper cables up to ski batteries or car batteries, the motor cranks like mabye 1rpm with the plugs in the engine. If you take the plugs out, the engine turns over fine.
Things we've tried:
1. Brand new starter
2. Different working bendix
3. Inspected flywheel off the engine - flywheel and key look OK
4. Apparently friend suspected washer on end of bendix was slightly bigger than ones he's seen in the past, so we thought maybe the flywheel cover was interfering with the bendix after it was tightened down. We loosened the cover bolts so there was an 1/8" gap between the block and cover - No change. Washer is on bendix end towards flywheel cover.
5. Pulled off crank case drain - No water in crank case
6. We eliminated the ebox, cables, etc by jumping the battery directly to the starter - Still slow crank with plugs in, cranks fine with plugs out.
I am at a loss right now. Any ideas? Has anyone seen this before? Thanks for the help. :Banane01:
Doug
Things we've tried:
Doug
