Yami-Rider
TigerCraft FV-PRO
- Texoma
Looks like the front crank bearing/flywheel side has been wiggling back and forth. Bearing still feels smooth, engines was still running when pulled apart. Motor had a lot of time on it, was going to replace the crank anyways, wondering if I put bearing loctite would stop it from wiggling? Or should I replace the cases?
Edit:
I ended up using loctite primer and 620 bearing retaining compound.
Edit:
