Crane
Peter123
C-Note
Houston, TX
Well, I finished my ski crane this weekend.
I basically built an I-beam out of 2x4's, used a 2,000 lb winch I bought at Northern tool on sale for $50 and a pulley (sp ?). I mounted it in my garage up in the rafters with the wench setting on a double header (4 x 12). I connected it to an extra car battery that was sitting around doing nothing, and I use a set of jet ski rail straps that I bought on eBay for $40 (rated to 750 lbs).
Well, after getting everything in place, I hook the power cable and control into the wench. I noticed that the control switch only toggled one direction. Apparently, at some point in the last 2 weeks, I had accidently thrown away the directions for the wench, so I climbed the ladder and looked to see if there was a reverse switch on the wench. There wasn't. There is only a knob that disengages (greater release with more turns) the wench allowing gravity to pull out the cable. :banghead: I tried reversing polarity, but that didn't work, so I'm stuck having to use the knob for lowering. Not a HUGE deal, but still irritating.
It works like a charm, other than no reverse, and the total cost was around $100. Now moving the ski between the dolly I keep it on and the trailer will be easy as cake.
If I could do it all over, I would spend the extra $50 to have a wench with reverse, and I would change a few things on the basic design; however, it will stay like this for some time.
Peter123
C-Note
Houston, TX
I'll have you know that I finished the crane so that I could get it lifted high enough to comfortably work on it. My plan is to pull the manifold and exhaust TONIGHT.
Penguin, do you feel up for poker this Saturday night? It's in your hood. Friendly game with $20 buy in and about 16 people.
