Hey, new to the sight but u guys seem pretty helpful. Just bought a 96 rn with a 61x and the cylinder is cracked. Should I sleeve it or just get new cylinders
jetx gave you your answer. If the bottem of the cylinder where it bolts to the cases is cracked then re-sleeving won't help. If the actual barrel where the piston lives is cracked then a new cylinder is cheaper.
