Compression imbalance after rebuid
How long does it take to run in a full Yamaha 701 rebuild?
1mm over sized rebore and pistons, new gaskets, seals etc
Ran 15ltrs max through it today varying the speed. Re torqued head bolts and girdled head bolts with very slight re-torque needed.
Brought it home to check it over.
Carried out comp test with good gauge. Wide open throttle, 1 plug in and held stop button whilst cranking. Rear achieved 200psi and the from 175psi (running a AM head with 33 domes)
Is this due to the running in period to have the rings mated correctly?
That amount of imbalance is not caused by break in (really no imbalance should be caused by break in), you either have something wrong with your measurement or something wrong with your motor.
If you have an aftermarket head with o-rings, I would pull it off and visually check for damage, then swap domes and see if the change in compression follows the domes.
New domes but will remove head today to inspect
