Cold fusion throttle
At last I have been getting around to installing my cf/rrp riser/Schmity steering. I've installed the turn plate, riser bars with odi rogue grips and have put the cf throttle lever on. The cable seems too slack, do I need an extension adapter for it?. I haven't put the clip that holds the throttle to the turn plate back on yet does this put it at an angle to then take up the slop?.
Regards, Ben
