I'm trying to troubleshoot a 92 sj that wasn't running last year, it was running but poorly, electrical checks as follows
Charge coil spec 365ohm +- 36.5 I have 381
Pulsar coil spec 14ohms +- 1.4 I have 17ohm
Lighting coil 0.9ohm +-.09 I have 1ohm
Do you think the Pulsar being out by 1.5ohm could likely be culprit? I checked rectifier and cdi they are in spec, I don't want to remove block if I don't have to, Im going to look into fuel supply next
Thanks
Thanks
