Clean Rickter xfs sold
2014 genuine Rickter xfs ninja glass hull carbon look. The hull is in great shape and as is the original turf.
Spec list
Yamaha 760cc motor fresh rebuild with only 16 hrs thrust head with girdle kit and domes.
44mm carbs with tau-cetti frame arresters, primer kit and thrust wheel.
Vforce 2 reeds
New 62t stator and new oem flywheel good clean used oem Bendix.
Black Billet thrust flywheel cover.
It has a extremely clean oem 62t ebox with msd enhancer and a Yamasaki jet maniac surf sealed coil with msd boots.
New oem start stop switch
Full tnt laydown exhaust with rrp water box.
Oem 155 pump fully rebuilt with 5-10 cut back.
Thrust 155 billet trim system -black
Rickter Worx intake grate
All new OEM Yamaha motor mounts and midshaft and housing.
Thrust billet pole with carbon chin pad.
Thrust adjustable billet steering red
Rrp 50mm riser bars
Thrust billet surf saver start stop switch-red
Thrust billet leavers-blue
Heavy duty steering cable and throttle cable.
3 gallon h20 designs fuel tank
New deka etx12 battery
Thrust hood latch-blue
Cold fusion hood prongs
Blowsion brapp straps (hood saver)
Thrust watt holes for bilge and primer
Bilge pump
Rrp hood scoop
Thrust billet pole bolt
Rrp pole bracket
Jet maniac rebuilt starter
Rrp foot holds
Everything on the ski works perfectly without any issues at all I will happily meet at a boat ramp for a test ride.
Yes the ski will flip with a boat wake or a lot of talent.
The ski is registered in fl and comes with clean Florida title.
For more info text me 386-264-5508 or message me.
$9999 shipping available.
I will part the ski out of the hull sells first !
