Change MSD to Cdi Unit
Buna ziua, am un motor Dasa 1200cc cu management MSD (Ignition Control Module), vreau sa schimb acest management si sa trec la Cdi Unit Sym JET... , dar vreau sa pastrez sistemul de pickup de la MSD si sa ma adaptez la Cdi, ce am opțiune pentru această schimbare? Mulțumesc.
Hello, I have a Dasa 1200cc engine with MSD management (Ignition Control Module), I want to change this management and switch to Cdi Unit Sym JET... , but I want to keep the pickup system from MSD and adapt to Cdi, what option do I have for this change?
Jr.
Standing Tall
Staff member
Hot-Lanta
there is nothing avail currently to use MSD TL pickups and flywheel.
But, Keep your eyes open for an announcement soon!
P
Do you mean going to a Stock OEM Yamaha CDI from an MSD Total Loss System?
If it's just the MSD Enhancer CDI, than it's an easy swap at the Electrical Box.
If it's removing the MSD Total Loss Control Brain, then the Yamaha CDI would need to be installed along with the matching OEM Ignition Coil, Stator and Flywheel.
Because the MSD Total Loss System uses TWO Ignition Coils, then it has Two Pulse Pick-Ups. The Stock OEM System uses only ONE Ignition Coil and ONE Pick-Up and fires BOTH Cylinders every 180 degrees of rotation, thus one Spark is wasted every firing and is called a Wasted Spark System.
By the way, what is happening to Andrew Tate in Romania?
Cheers
Thanks for the information, I saw the wiring diagrams for both variants. About Andrew Tate is detained by the authorities for thirty days. Thank you!
