carbs
Having trouble with carbs. One carb is jetting a lot more fuel on idle then the other.
I have pulled carbs apart cleaned them and put back together. I have check needle and seat on both and they both are ok.
Motor is entire new build, carbs and reeds are from previous motor.
I will attach videos
You can see lots of fuel getting sucked out and its only idling and its kind of spitting the fuel around not even sucking out cleanly
