Carbon build up
Or lack there of.
I have been running this motor for a few hours and am seeing almost zero color change of the piston. Basically no carbon build up at all. Is this a bad thing? Running 32:1 right now for break in.
Pump gas. 190 psi .046" squish, 107.5 main 130 pilot,1.8 needle seat, 22 psi popoff, 38.5 cc domes blowsion head, ngk br8es plugs.
Blackjack 44s if that plays a part
dfw
Piston tops will stay clean until you get them hot. A freestyle ski with big pilots and little full throttle use will have very clean Pistons.
