SOLD Carbon Bob Gen 3.5
This full carbon-Fiber Bob Gen 3.5 was the last Hurricane Industries Bob built and will be the last built by Hurricane Industries. It is also the only vacuum bagged Bob ever built.
The Hull is in amazing shape and the only downside is the white turf which has seen its better days and minor rash on the bottom. One of the bolts holding the ride plate to the hull was seized and needed to be drilled out, half of the bolt is still in the nut insert. The overall construction of the hull is in perfect condition and just minor cosmetic wear and tear. Turf is in acceptable condition.
The Hull comes with: Hurricane Industries Footholds, 144mm Pump Shoe Ground Out to 148mm, Super Jet Battery Box Modified for Power Factory Water Box, Intake Grate, 3 3/8" Water Fittings, Bilge Pump Fitting, Bilge Pump with Wiring and 3 Way switch, All hull hooks.
Many of the photos dont show the hood or footholds, but they are included
Purchased back in January and had it shipped from California to Florida - was going to build it up, but purchased a complete Rickter instead! Hull is located in Gainesville FL
