carb up grade jetting
douglee25
m3booooy
South Jersey
Jetting will vary from ski to ski, but you may be alright with the same jetting. Lowering the pop off will probably be required because the velocity of the air has slowed down going through a bigger venturi.
Try without adjusting anything and see how it runs. If it's not correct, lower pop off and then try again.
Doug
