Carb tuning Q
Dual 38's on a 701 with protec pipe.
Ski was lacking power and the carbs were well overdue a rebuild.
Was before and after the rebuild - 1.5 N&S, 115g (55psi pop off) 135 H and 72.5 L, H 1 1/4, L 1 3/4, Vforce 2 reeds but it was a dog to tune and heavy flat spot so changed the pop off to 95g (40psi pop off) and it ran unreal but if I come off in water and try to side mount it takes a second or 2 to clear it's throat before it pulls me up.
No other problems apart from that and I never had this issue before changing the springs so I'm thinking the pop off is too low or could the low's be out to much?
