Carb question
Tried searching this topic but found nothing. How are you guys mounting the throttle cable with a throttle drum installed? Or another way to ask is how do you torque down the bolt on throttle side with a throttle drum installed? Reason I ask is because I have zero room to tighten the bolt now
with a throttle drum installed. The stock drum has a semi-circle-like shape so I was able to slide my wrench underneath it to bolt down the carb. Figured I'd ask before buying a bracket that mounts on the diaphragm or fuel pump side. Or I might just chop the bottom third off of the drum to make some wrenching room. It's a single sbn46 mounted as usual with fuel pump facing outwards.
