SkiDaddy
Just Havin' Fun!
- Orange City, FL
In the past couple weeks my SJ was running kinda rich off idle, & I noticed it was dribbling when revving down to idle. So I replaced the needles & seats, went out today & it ran great the first session. 25 minutes into the second session the richness off idle was back. It got progressively worse, at anything above idle, to the point where it would barely run at 2500 RPM or so even at WOT. Went to shore, spark looked weak in the bright noonday sun, so I changed plugs. Same problem, felt like it was still running on only one cylinder. Problem exists in & out of the water.
Got home, flushed, tried pulling the rear plug wire & grounding it w/an old plug. It started & idled on the front cylinder, but immediately ran super rich at anything above idle. Put the wire on just the rear cylinder, ran strong & crispy, it actually ran better on the just the rear cylinder than both.:bigeyes: . Switch plug wires, plugs, same thing. Definately a front carb (stock 38mm) issue.
I've pulled the carb apart, checked the fuel filter, needle & seat, sprayed carb cleaner through the jets, visually looked for a perforated diaphragm, or fuel valve disks. Saw nothing unusual. I also felt the reed petals, they're all intact & sealing well as best I can tell; plus, the front cylinder alone will start & idle just fine. Reassemble, exact same behavior. Front plug is quite wet w/fuel. Rear plug is fine.
At this point I'm stumped.:frown: Any ideas guys? Cracked carb body?
